Release type: Release
Exclusive to beatport: No
Eating Hooks [Monkeytown Records] is available for download on Beatport, the world's largest DJ and electronic music community.
Tagged by: Mp3Tag w/ beatport.com scripts [v5.0 by stevehero™] (◣_◢) (http://bit.ly/2EmyidV)
But see screenshot of how it's displayed in Mp3tag. It's a FLAC file.
Drat.
I wrote "carriage return" and "newline" in chevrons and apparently they got eaten by the editor.
So my replay in its full beauty should have been:
Doesn’t this field require "newline" and "carriage return" to get a proper line break?
So if you remove the "newline" it is sort of broken, I suspect.
What does an unsyncedlyrics field look like in NP++ that you have editted in MP3tag?
It could still be that you have to set something in NP++ so that proper end-of-paragraphs are created.
Or you could check with a filter whether UNSYNCEDLYRICS contains \n and \r or just one of them.
\r translates to carriage return (CR, ASCII code 13) to tell the "typewriter" to push the carriage back to the left so that the cursor is back to the start of the line. \n translates to line feed (LF, ASCII code 10) which moves the cursor down the page one line. It's ancient technology, but \r\n is still what's used on Windows.
