I wonder if there's an update, since I found e.g. "findinline 1 1" which isn't covered here ...
.sundance.
.sundance.
there are many undocumented commands. i found some by looking at other people's scripts and looked them up on the forum. if you search there, you will stumble upon some explanations.
we could collect them here and add description, so Florian would only need to copy and paste them into the oficial documentation if we do a good job.
i found expanation for this command here:
moveline to empty line fails
as far as i understand
findinline 1 1
findline 1 1
prevent the script to terminate (producing an "" ouput for into the current tag field and stopping there) when it does not find the string it is looking for. instead the parser goes to the end of the line for <findinline 1 1> and to the end of the site (i think) for <findline 1 1>.
i use the <1 1> almost always with and as it prevents scripts from error stops.
So far I have collected these function calls ...
Do
Else
EndIf
Exit
FindInLine "<!--Themes Listing-->" 1 1
FindLine "<span>AMG Album ID</span>" 1
FindLineNoCase "<span>AMG Album ID</span>" 1
GotoChar 1
GotoLine 1
If "Review"
IfNot "</ul>"
JoinUntil "</TD>"
KillTag "*"
MoveChar -18
MoveChar 9
MoveLine 1
MoveLine 5 1
MoveLine -6
OutputTo "CoverUrl"
RegExpReplace "(?![a-z])/ (?=[A-Z])" "/"
RegExpReplace ",\s\w+$" ""
RegExpReplace "\s,\s{2,}" ", "
RegExpReplace "\s\(\d?\d:\d\d\)" ""
RegExpReplace "\s{2,}" " "
RegExpReplace "\s+" " "
RegExpReplace "\s+$" ""
RegExpReplace "^\s+Label:\s+" ""
RegExpReplace "<Binding>[^<]+</Binding>" ""
Replace "<pre>" ""
Say " "
SayNChars 4
SayNewLine
SayNextNumber
SayOutput "CurrentUrl"
SayRegExp "(?<=<Author>)[^<]+(?=</Author>)" ", " "</ItemAttributes>"
SayRegExp "(?<=<event date=\")[-0-9]{4,10}(?=\"/>)" ", " "</release>"
SayRegExp "(?<=<Label>)[^<]+(?=</Label>)" ", " "</ItemAttributes>"
SayRegExp "(?<=<release id=\")[-0-9a-y]{34,40}(?=\" )" ", " "</release>"
SayRegExp "(?<=<ReleaseDate>)[-0-9]{4,10}(?=</ReleaseDate>)" ", " "</ItemAttributes>"
SayRest
SayUntil " - "
UnSpace
While "</a></li><li><a href"
DD.20101014.1727.CEST
but most of them are documented here:
https://docs.mp3tag.de/tag-sources
regular expressions are documented here:
https://docs.mp3tag.de/actions/replace-regexp
what is undocumented is
the additional 1 in:
from your list:
but I think there are still more commands. i remember looking through dano's scripts and finding some things i didn't know. I will have a look.
edit:
another good thing would be further explanations for the already ducumented commands, with some expamples. it took me some time in most cases to understand how they work.
at some, i haven't understood fully yet.
anyone care to explain what 'Exit' does?
I found this in a script.
do
if ...
exit
else
endif
while ...
I think it's to exit of the do ... while process if a certain string is found.
But I don't know exacty.
