From the FAQ:
Question:
There are irish/scottish names like O'Donnel, O'Leary etc, that all should be upper case. But you cannot use upper case in general after an ' because the following examples are wrong spelled then (That'S, Ain'T etc.). How can I only get upper case after an O'?
Answer:
Create a new action in an existing action group and choose Replace with regular expression as action type.
Regular expression: O'(.{1})
Replace matches with: O'$upper($1)
This doesn't appear to work. It catches O'Hugo OK, but it also turns "Romeo's" into "RomeO'S".
Or did I do it wrong?
TIA...
