Hello,
I am trying to change my filenames from lower case to upper case but when i do that it says that file cannot be renamed and file already exists. What am I supposed to do? What is the wrong?
Thank you
Thank you for your response. But still doing nothing. I tried. If someone can upload some screenshots how can i do it..
Select the files.
Use the function Convert>Tag-Tag for _FILENAME
Format string: $upper(%_filename%)_
Now use the same function but use
Format string: $replace(%_filename%,_,)
That works!! Thank you very much and excuse but my english are not good enough to explain you!! Thank you again!
For the second step recommended: $trimRight(%_filename%,'_')
DD.20170711.1120.CEST
