Use Filter to find Duplicate Lyrics
#1
Is it possible to use the filter to list all non blank Duplicates in the Lyrics tag?
Thanks
#2
If you mean a comparison between at least two files then the answer is "no" as mp3tag only looks at one file at the time and does not compare any two files.
#3
Thank you for your fast reponse.
#4
Wasn't very satisfying, right?
But honestly: all you can do is setup a column for the field that you want to compare and sort by it. So you have at least those close to each other that start with the same words.
