I have a User Defined Tool as follows:
Path: C:\Program Files (x86)\Mp3tag\Mp3tag.exe
Parameter: "%title%%_filename%"
all selected files = check
I use a "reference file" for each of my podcasts (1 per podcast) that has the path = %title% and the same filename as the directory name of the target folder (e.g., %title% = I:\Podcasts\ %_filename% = This Week in Virology). In my example, running the Tool opens the corresponding folder for the selected "reference file" ... works great.
However, now I am downloading my podcasts to one hard drive and cleaning them before moving them to their home drive (too many podcasts ... so now multiple networked hard drives).
Is there a way to have 2 parameters for the tool and have them both open in MP3Tag (Parameter: "%title%%_filename%"; "g:\itunes\iTunes Media\Podcasts%_filename%")?
Alternately, is there a way to run Tools twice and have both results end up in the Mp3Tag working window (sort of like using CTL+drag to add folders)?
Tx
