Hi, Noob to the software however by browsing through the community thread I see that there's a way to update fields via the tag-tag function and I've been able to do some basic things using the examples others have provided. I have a number of audiobooks that are all using the same filename convention but I have not been able to figure out how to do the below.
An example is the filename "Wells, Martha - [The Murderbot Diaries - 7] - System Collapse 2023.m4b"
I'd like to be able to pull the series name "The Murderbot Diaries" into the album field. I would also like to pull the number inside brackets into the track field. The number can be up to 3 digits and can also contain a decimal so in the above, the 7 might be 7.5 or 17.5.
Finally, there are some cases where the book doesn't belong to a series. This would be denoted by [The Murderbot Diaries - 7] being instead [ - ]. eg. "Wells, Martha - [ - ] - System Collapse 2023.m4b"
In those cases, I'd like to make no changes.
Not sure if any of this is possible but would really appreciate any and all guidance. Thanks in advance.
