I am using the Text file converter to do batch stuff and it's working great. Is there a way I can have it look at my hard drive for a specific cover art file (jpg) and automatically put it in?
Example Line from my Text File:
SongTitle\MyAlbum\MyArtist\97\MyPublisher\Composers\BandURL?????????????\Comments
Good idea to use a temporary user defined tag field for holding and providing the filepath of the cover image file for later importing the image file.
Hmm, if %coverpath% carries a filepath including backslashes, then OP Fridayspast will going into trouble. He will need to change the Backslash separator of the import format string to a different but unique character, e. g. the Star symbol * or the Pipe symbol | or something else character.
Using the Import Cover File works great, of course. But, I'm trying to get it all in one action. The Alt+4 Text File -Tag action.
SongTitle\MyAlbum\MyArtist\97\MyPublisher\Composers\BandURL\C:\MyPic.jpg\Comments
The problem is C:...That backslash messes it up. I tried using another character as suggested but that didn't work, it just takes this as text and imports that line, but nothing happens. I was hoping I could put "" around it or something so it knows this is a PATH to the Cover Art to import not text...
No, why?
Dano's proposal will work as expected when respecting my proposal to adapt the separator character to the new situation.
The convert procedure "Text file - Tag" can only import textual data from a prepared column oriented text file.
The action "Import cover from file" can import binary data from an image/picture file.
Dano's proposal is ... to set a user defined tag field %COVERPATH% with the actual filepath to the cover image file.
After setting the tag field %COVERPATH%, then in a following step, the action "Import cover from file" can use the content from this tag field as the format string for the image file, which should be loaded as a cover image into the current track file.
A sample line of your text file should look like following:
(To avoid problems due to space character the filepath should be enclosed in double quotes.) SongTitle|MyAlbum|MyArtist|97|MyPublisher|Composers|BandURL|"C:\My Folder\My Picture.jpg"|Comments
The related import format string should look like this: %title%|%album%|%artist%|%bpm%|%publisher%|%composer%|%wwwartist%|"%coverpath%"|%comment%
If anyone reply to this and confirm that the above steps are correct? Because i follow the steps and the image do not appear in the tracks.
So if i understood correct:
We go to Mp3Tag and we create a custom column with name = Coverpath, Value = %coverpath% and Field = %coverpath%
In the txt file we format it as above SongTitle|MyAlbum|MyArtist|97|MyPublisher|Composers|BandURL|"C:\My Folder\My Picture.jpg"|Comments
The import format string must be as above %title%|%album%|%artist%|%bpm%|%publisher%|%composer%|%wwwartist%|"%coverpath%"|%comment%
And finally after the upload the image should be visible in each track, without the action drag and drop the image or import with shortcut Alt+4. Is this correct?? Because the image is not displaying, probably i'm doing something wrong.
Yes i forgot the forth step. After all the above i go to convert and click Text File - Tag and import the txt file with above format. But the image do not display. Is it possible, if you have the time to upload some image with the configuration or steps how you do it. Thanks in advance.
The cover will appear only after you have started the action "Import cover" with the reference to the user-defined field in the format string.
Simply importing the data from the text file is not enough.
If you are looking for the link to the cover, check the extended tags dialogue (Alt-T) to see if the field is there and whether it has the correct contents.
Then create the action to import the cover with
Format String: %coverpath%.jpg
provided, the user-defined field for the link is called COVERPATH.
One last question is it posssible to set for this action a shortcut??? e.g. Alt+Key something?? I mean the specific action not the Alt+6 for all the actions
