Using the if function to check if "(feat." exists in title
Hello everybody, back with my daily question.
Today, I'm looking to check whether or not "(feat" exists within a file's TITLE field. I have an expression that will run if so, but I just need help with the identification portion.
Optimally, These should be recognized:
Track 1 (feat. Artist2)
Track 2 (Feat. Artist2) (remix)
But not these:
Track 1 feat. Artist 2
Track 2 Feat. Artist 2 (remix)
Like $ifgreater($strstr($lower(%title%),'(feat'),0,yes,no)
replace the "yes" and "no" with the functions that should be carried out in each case
Great, that worked well. Could you tell me if there's any reason you used the $ifgreater function instead of an if(x,y,z)?
I'm just unsure the difference. By the way, you've helped me complete this:
$ifgreater($strstr($lower(%title%),'(feat'),0,$meta_sep(artist,\\)\\$regexp($replace($replace(%Title%,',' ,\\), & ,\\),'^(.+?)\s+[[({]?(?:ft\.?|feat\.?|featuring)\s+([^][(){}]+)[])}]?(\s+.+)?$','$2',1),$meta_sep(artist,\\))
Which will add a featured artist or multiple to the existing artist list only if there is one to add, but is safe to use on all files :slight_smile:
$strstr() returns the position as a number. The number is 0 if there is no hit.
So it checked for any value higher than 0 as this indicates that the search-string is somewhere in the source string.
I see - Thanks for the explanation!
