Really useful would be the following Export script System placeholder:
%_index% Current value of the index of the immediately containing loop
Also, in Help, %_counter% would be more clearly described as
%_counter% Current counter value (ascending from 1) of the immediately containing loop
I don't see the difference of these two placholders. Can you give an example?
chrisjj
November 15, 2007, 2:27pm
3
Sorry to be unclear - by "the index" I mean the field/expression argument of $loop().
The export script
$loop(%_filename_ext%)%_counter% %_index%
$loopend()
would output e.g.
1 myfirstfile.mp3
2 mysecondfile.mp3
I'd use %_index% instead of having to repeat the long expression that I often have in $loop() e.g. one to find the UPC and other info from folder name.
Now I think about it, parhaps it would better for Mp3tag to allow this:
$loop($put(v,%_filename_ext%))%_counter% $get(v)
$loopend()
