based on the release notes i thought this issue was fixed:
however, i'm not using discogs web sources, but do have some scripts with multi-valued tag fields.
in my scripts i had been using:
this hasn't worked since 2.49b and now it doesn't work in 2.50 either, the newer versions just output a single backslash.
is there a coding change in the web sources language i need to apply to my scripts?
i tried changing to 6 backslashes, since using the 4 backslashes was resulting in only a single backslash in the tag panel, but that doesn't work. 4 or 6 gets translated back to 1 backslash.
then of course upon saving the tag, no multi-valued tags are created.
any help would be appreciated.
hopefully there is a way to fix, i don't want to be stuck at 2.49a indefinitely.
I don't know why the release notes say it is fixed. I have made the same experience as you.
However, the workaround is, you have to double the backslashes compared to version 2.49a, eight backslashes to have two backslahes in the output:
say "\\\\"
Another workaound is using the unicode hex value. This was new introduced in 2.49b. The unicode hex value for a backslash is "005c". Write "\u005c" to get one backslash. For two backslashes
say "\u005c\u005c"
Here is a German topic about the same issue: [F] Mp3tag 2.49b: Änderungen bei Web Sources?
Have a look at the test script I attached to the last post there, this will make things clear.
