I just removed v3.34.1 that today just fail to represent Japanese characters. Showing only little bixes - simillar to checkout boxes.
I tried opening files updated before this crash abd 33.34.1 still fail. When any other app on win was playing the mp3 files and showing the actual characters properly.
Hence I remove 3.34.1 + erased the folder at c program files. And then re installed prion
ver for winx64 3.33.1 modifying the folder path with extra characters and that works fine perfectly
Hope you can look at what happened with latest version, that for some unknown resons got crazy and no longer use/read proper character set (whatever the ascii ANSI or any othe5 else char set table code that should be using to represe t foreign languajes - but 3.34.1 just lost it.
And please consider that this to allow cop/paste text ... i dobt care about translating in-line to show both occidental translation and at right side the traducion and locale charset (if you can have that all solved will be ezxeñent, meanwhile i just sesrch the web translate and copy/paste for now)
