Valid Response from FreeDB
When I try to freedb determine by selected files it give this error msg:
Mp3tag V.2.34a
The server failed to return a valid query response code
OK
Is there any way to know if it is the freedb server problem? or the problem ir here?
Can you please increase the timeout value at Options > freedb > Server to 15 and try again?
If this doesn't work, switching to another freedb mirror might solve the problem.
Best regards,
~ Florian
