The obvious thing to try is Filename->Tag. So I tried this, but I did not manage to come up with a way to consider the optional second title thing and the variable number of spaces.
However, I managed to describe the name with a simple Regex:
$1=artist
$2=title
$3=album
Is there a way to edit multiple tags at once with a regex?
As long as the pattern of data an separator stay the same, you are fine
e.g.
artist - album
(space-hyphen-space)
and
artist - album
(space-space-hyphen-space-space)
it can be split into various fields: use only the single space.
You end up for the double-space construction with extra spaces at the end of the artist field and a leading space for the album field.
You may then apply a format-value-action with the $trim() command to get rid of these spaces.
Or you run 2 "replace" action over the filename that first replace every hyphen-space with space-hyphen-space and then all double-spaces with a single space.
Finally you use a "Guess value" action for _FILENAME
with the pattern you would have used in the convert filename-tag-function.
The way I understand your solution, is that it only works for every category when seperated by a sign
The thing is, it is not always like that.
It can be 'artist - title (album)'
or 'artist - title (still title) (album)'
Brackets are in the filename as written.
So the 'still title' part is optional and not actually seperated from the album part.
Yes, you have to adapt your masks to the unique separator for each pattern.
If it is a different pattern, you have to use a different mask.
Or you manipulate the original data in such a way that in the end you have a universal pattern - whatever is easier for you.
Even though the action is called "Guess values" it does not do too much guessing but sticks to the supplied masks.
Your situation is ...$1=artist$2=title$3=albumDimitri Vegas & Like Mike,Moguai,Julian Perretta - Body Talk(Mammoth)(Original Mix)1------------------------------------------------- 2-------- 3-----------------------EDX - Everything(Cazzette Remix)1-- 2--------- 3---------------EDX- Everything(Cazzette Remix)1-- 2--------- 3---------------Proposal 1 ...Action GroupAction "Format value"Field: ARTISTFormatstring:$regexp(%_FILENAME%,'^(.+?)\s*-\s*(.+?)\s*(\(.+\))$','$1')Action "Format value"Field: TITLEFormatstring:$regexp(%_FILENAME%,'^(.+?)\s*-\s*(.+?)\s*(\(.+\))$','$2')Action "Format value"Field: ALBUMFormatstring:$regexp(%_FILENAME%,'^(.+?)\s*-\s*(.+?)\s*(\(.+\))$','$3')Proposal 2 ...Action "Guess values"Source format:$regexp(%_FILENAME%,'^(.+?)\s*-\s*(.+?)\s*(\(.+\))$','$1===$2===$3')Guessing Pattern: %ARTIST%===%TITLE%===%ALBUM%To remove round brackets from the tag-field ALBUM, you have to do an additional step.
Ohrenkino, I see what you mean.
I decided to go with DetlevD's second proposal as I do not have to rename anything at all.
Thanks you both for the help, I really appreciate it.
