I have recently installed ver. 2.54 and now it is very slow writing tag data. It taking minutes to write data 75 files. My machine still runs XP Pro which worked OK with previous versions. Should I go back to a previous version?
Yes, I would say so. And then you can test if it is really the new version or something else you have changed in your local pc environment.
