I read the topics concerning adding multiple values to a field, such as, "Dave Matthews\\Tim Reynolds" for ARTIST. The problem I am experiencing is that when I do this, the only ARTIST visible is the last one I list, so "Tim Reynolds" in my example. How do I determine if it is actually retaining the second ARTIST?
For reference, my MPEG settings are:
READ
x ID3v1
x ID3v2
WRITE
xID3v2
ID3v2.3 UTF-16
REMOVE
x ID3v1
x APE
I am working with Windows XP (laptop) and Vista (desktop), windows media player, and Zune software. My use of your product is to fix issues with Zune tagging, and your software has been fantastic.
I'd try to avoid converting the files since it's always with a quality loss. But it's your choice, I don't know how badly you need this feature.
Maybe multiple WMA tags will be supported in one of the next versions and you can wait.
