When I update the genre field for an MP4 in Virtual DJ, it reads correctly, but when I then read the tag in MP3TAG, there are extra characters. I'm not sure if VDJ adds these characters or if MP3TAG does.
Example: In MP3TAG, I will rename genre fields as needed. Say, Rock. I'll then import the files into VDJ. I then make changes to other fields (Key, bpm etc) in vdj, but not the genre field, and click the 'write' button. This writes all updatable fields to the id3 tag in the mp4 file. Now, when I go back into MP3TAG, the genre field for this file reads as follows: Rock\\Rock.
If I update the genre field to say, Rock/f (which means it's a fast rock song) and save the tag in VDJ, MP3TAG reads the tag as Rock\\Rock/f. Still reads correctly in VDJ.
Any explanation for this?
Thank you
