Web source debug question
Is it me or the "^" is four chars before the end in debug?
imagem
the output is correct.
most of the times is in the correct position.
It's probably related to one command not correctly incrementing the internal position pointer. Can you identify at which command it becomes incorrect?
After some testing, i use 'Unspace' to remove the spaces before the html, i had assumed the spaces did not count(don't know why i never noticed all of this years) and now the '^' is in the right place, everyday i learn something new, again thank you Florian for this great software.
