Websource Script Error "Parameter 3 is unexpected" - What do do now?
Since the newest Mp3tag v3.21c, my Websource-Script says:
How can I fix this?
I guess you have to remove the 3rd parameter then.
After commenting out this line
debug "on" "C:\Temp\MB\MB_debug_json_EXPANDED_album.txt" "50000"
it seems to work again.
The (3rd) number seems to be unnecessary and invalid now?
Thanks for pointing! It seems that I have a inconsistency between the internal function specification for debug and the documentation.
It's not active in the release version of your script (I've tested this), but will fix in a few minutes.
I've now fixed this with Mp3tag v3.21d. You most likely need to make the 3rd parameter strictly numeric: "50000" → 50000
I changed the debug lines to the numeric 50000 and tested it successfully.
Thank you for the very fast v3.21d fix.
