I'm trying to insert an incremental letter on multiple files. For example:
A04a Bongo Sounds
A04b Bongo Sounds
I would like to put a capital A at the end of the first file, a capital B at the end of the second file and so on.
I'm using this string in filename - filename:
$char($add($num(%1,1),65))
But all it does is place an "A" at the end of each file. Is the string not accurate? I don't want the same letter repeated for every file. I want the letter to adjust incrementally.
will always be 0 as an "A" is no number and therefore the numeric value = 0.
see also your post from a couple of days ago:
To get an incremented letter at the end of the filename of the selected files, do not use Convert>Filename-Filename but Convert>Tag-Filename
Format string: %_filename% - $char($add(64,%_counter%))
Will 64 always be "A"? With the other string I would have to regularly change the number to get "A", as there seemed to be no consistency to it. What is the cycle of characters that the numbers will input?
