A surge killed my motherboard so I didn't get a chance to backup MP3Tag internally but I do have backups of the drive. What files do I need to move to 10 to keep everything that same as I had it in XP?
See the FAQs: /t/964/1
From the way that read I had to backup the setting via MP3Tag. I didn't do that. I only have the installed files and their backup. I found the zip file "Mp3tagSettings.zip" and it's close to the day the computer died but I didn't know if this would work since I didn't create it.
The alternative is that you install MP3tag on the new system and copy all the old files from the data and export folders to the new %appdata%\mp3tag folder
Thanks
