I have several albums (Folders) where the meta data no longer showing or hidden in MP3 Tag Editor. The information is still embeded in the files, but will not show in the Editor.
There seems to be no logic as to which folders are impacted. Not sure how long this has been going on.
I think i found the issue. A[[arently in previous formating I was reading/ writing APE.... those were the files i could not see... So far the issue has been resolved for the few files I've found.
If you have the same problem then it should be easy to apply the same solution.
So: what are the settings as DetlevD wrote in post #2?
What happens if you disable to read APE?
