What is the constant of blank? For using in Action Replace.
for exsample
%GENRE%
original: null or empty field (constant of blank used here)
replace to: Pop
for exsample
%GENRE%
replace to: Pop
As there are no empty fields - if data is not set for a field then it does not exist - use an action of the type "Format value" (in this case for GENRE) to fill a field with data.
OK, get it,
many thanks
If you want to reuse existing genres and only add Pop for empty/non-existing genres, you can use
$if2(%genre%,Pop)
as format string — or use the Filter before applying the action.
