Problem: When Editing on Secondary Monitor, A Field Update Will Causes a "reading directory" process to Resolve only The Currently Selected File (i.e., the window contains one file).
Things to think about:
This problem doesn't exist on the primary monitor.
I uninstalled v2.94, then installed v2.90 to find the same problem.
I can drag the windows to the primary monitor and the problem goes away.
My Environment:
Windows 10 1809
two monitors:
(3200x1800) primary Laptop display 225% scale
(1280x1024) seconardy external 100% scale
Settings:
Tags; both, "Save tags when..." and "Preserve file mod..." are ENABLED.
Does anyone else have a similar problem, or have heard of this problem?
Thanks,
That is my experience as well. On my ancient workstation it is fine.
I have an older (unsupported) Dell Inspiron 6400 also with a discrete video card running Window 10 1809, and:
1. (1280x800) Primary laptop display 100% scale.
2. (1280x1024) Secondary external 100% scalle.
and have no problems.
Just some quick questions: What is your scaling factor? are you using a 4K?
thanks
When I was bought an ultrawide monitor 2.5 year ago I was using it for a while along with my old one- and was tampering with Mp3tag
Unfortunately I do not remember if it was the first model that had 2560 x 1080 or the latter one running in 3440 x 1440; but the old monitor had 1920 x 1080 for sure. But I had no such problem,at least on Windows 7 x64. So that also tells us that a specific combination must be a problem; and / or the problem is something new as it was not present in earlier versions
yup. I just tested it on v3.01.
Since this original report I have swapped my primera displays and determined that the problem occurs on the éxtended'secondary monitor.
Could you shed a little light on all this:
How are the monitors connected to the PC? Individually each with its own port or via a Y-cable?
Is the graphics driver up to date?
Are there other programs running that hide somewhere at the edge of the display?
Have you tried to run MP3tag with a fresh mp3tag.cfg file (e.g. close MP3tag, rename the old one and see if a new start brings a change)?
Have you tried to disable both the options
