Where are the default actions
Where asre the actions described in the help file such as
■Case conversion
■Convert codepage
■Export
■Export cover to file
■Format value
■Guess value
■Import cover from file
■Import text file
■Merge duplicate fields
■Remove duplicate fields
■Remove fields
■Remove fields except
■Replace
■Replace with regular expression
■Shorten filenames to 64 characters
■Split field by separator
When I open the actions all I see are Caser Conversion, CD-R and Standard.
Thanks
In the action window, click on :mt_new: , enter a name and click again on that icon.
