where is usrfields.ini?
#1
Hi all,
Further to my recent post, and also another regarding storage of user data, I looked for usrfields.ini and couldn't find it anywhere in c:\program files\mp3tag (or anywhere else on my c drive, for that matter.) If I just create the file, will it be written to the next time I try to save user data?
#2
freedb and Web Sources
Before you start messing with config files I hope you know what you are doing.
#3
Thanks for the url. I DON'T really know what I'm doing, it's just that I keep losing a very long tag-file construct that I've worked on, which disappears each time I restart mp3tag. My guess is there's an ini file that's corrupted, or something. Florian has told me in a previous post that it should be available from a drop down selector, but honestly it isn't!
