Which Regular Expression engine and syntax is used by Mp3tag?
I read that MP3Tag uses Perl's regular expression engine.
Can anyone tell me which version of Perl is MP3Tag using? TIA.
I'm not using Perl (as the Perl engine) in Mp3tag — it's all C++. As regular expression engine I'm using Boost.Regex which has a perl regular expression syntax.
I have spent days working on an action group that I cannot get working.
I have just discovered, at regular-expressions.info, that there are Lookbehind limitations in Boost and/or Perl.
If I know which version(s) MP3Tag is using, I can check whether the regex feature I wish to use is supported, without spending days trying to get unsupported regex features to work.
Yes, as far as I know lookbehind must be fixed length. Here is the documentation for Boost.Regex included in Boost 1.70 which I'm currently using.
Many thanks for the confirmation and link.
