Hi there!
I've been using your program for a long time and love it, but I really think it could use flac support.
If this has already been discussed I apologize, I couldn't find it.
Thanks again!
Hi there!
Thanks again!
Do you mean something special with "FLAC-Support"?
As long as I know MP3Tag it can deal with FLAC.
Huh???? Almost all my use of mp3tag is with FLAC files.
The same here. I started using FLAC almost exclusively for everything.
The only time I use MP3 is when I export (and convert on the fly) my library files to my portable MP3 player, using MusicBee (another wonderful piece of software!).
We can use FLAC/Vorbis tags without any limitation using Mp3Tag.
The only sad thing is that sometimes we have to do some mappings (manually) for things to work properly.
VorbisComment DATE Year
VorbisComment ORGANIZATION Publisher
VorbisComment TRACKNUMBER Track
VorbisComment SOURCE MEDIUM MediaType (source for the digital files: CD, FLAC, MP3, etc)
VorbisComment ORIGIN WEBSITE WWWAudioSource (Web site: MusicBrainz, Lat.fm, Discogs, etc)
VorbisComment INITIAL KEY InitialKey (only for classical Music)
You can check these two links with the real mappings Mp3Tag and MusicBee are using:
Mp3Tag: https://docs.mp3tag.de/mapping
MusicBee: http://musicbee.wikia.com/wiki/Tagging
That will help you decide what to do. ![]()
As for standards:
Vorbis/FLAC:
https://wiki.xiph.org/VorbisComment
ID3v2 (used by Mp3, but also as base for others):
http://id3.org/id3v2.3.0
