wlx_anytag 0.94 problem
Before editing the tags of an album it shows the tags. After touching the tags with Mp3tag 2.35 (always write ISO-8859-1 tags instead of UTF-16 it NOT ticked) the wlx_anytag shows no tags in the artist, album, ... etc. fields (see attached pic).
The tags are OK anyway, I checked them in foobar, WinAmp and hardware player too.
If I tick the always write ISO-8859-1 tags instead of UTF-16 ON, and save the tags like that, the plugins shows them.
If I use EAC & lame all special characters are saved; and the plugin displays them correctly.
Using WinXP SP2 Home (Hungarian)
My problem or there are some incompatibilities?
Cheers,
::Krobb::
If I am not mistaken, the plugin does not support UTF-16 yet.
Oh, my bad. I thought it is. :frowning:
That's a wonderful plugin and I check all my music files with that to see if they are correct or not. Hope an update will come soon.
Thank you.
I've updated the plugin to support ID3v2 tags in Unicode format.
Download
