WMA and WM/MCDI Tag copy
After exhaustive searching your program seems the only thing coming close to what I need.
Rather than bore you with the details... I want to copy tags from set of WMA Losseless files to another set WMA Losseless files.
Your program does this thankfully!
It seems to copy all the pertinent tags except for this one:WM/MCDI
I want this standard tag (which is created by Windows Media Player by the way) copied with all the others. Is there a way I can get around this?
