Hi !
How to insert a skin file *.wma (windows media audio) ?
Mp3tag supports wma files with skins?
Hi !
I apologize. I use a translator...
meaning the Cover
Right click in the area where the Arrrow Points to, and Click Add Cover.
If you Right Click in that area, you will see the following Options.
Add Cover (Is to add a cover to a Music File (WMA, MP3, FLAC, M4a etc)
Remove Cover (Is to remove / delete a cover from a Music File)
Extract Cover (Leave the Cover in the Music File, but makes a copy of the Cover on the Hard disk)
The other Options are not so important for now.
After you add the Cover art, you have to click on ![]()
or on CTRL + S (Which is Save TAG). This saves the Cover Art in the Music File.
Try it out. And for your first tries, try it on a Copy of your Music File.
I would like to add that some WMA files are protected and cannot be edited. But Mike_nl laid out the general proceedings.
Mike_nl
exactly what I do
ohrenkino
No, these files are not protected
