WMP songs to mp3
How can I transfer Windows Media and data (songs) player to mp3 player?
I am not sure what you mean by
Are these WMA or WMV files?
And do you want to copy them to an MP3 player? Then this is a task for the WIndows Explorer.
If the files have to get converted to MP3 then you need a suitable converter.
Depending on the features of the converter the metadata will be kept.
You may need to convert to mp3. There are many free easy converters, google'll find a lot.
Mediapuge can convert whole directories at once
Don't forget to setup ffmpeg on configuration -> decoder/encoder settings.
ffmpeg release can be found here:
https://www.gyan.dev/ffmpeg/builds/
