Workflow improvements
  • Please make the Windows 11 feature work where the mouse pointer moves automatically to the selected (and presumed) default button... like the "OK" button so the mouse doesn't have to be moved to the button every time
  • When you select a new folder to tag, don't open to the directory of that folder. Just stay on the same level (makes navigating to the next folder to tag easier... no need to move up 1 directory level after each folder is tagged. Double click to put the individual tracks into MP3Tag and shift-Click or Cntl-Click to open the folder to access a single track to tag. Double clicking to load tracks to tag bypasses 2 steps and avoids having to click a button.
  • With the above change, when you click the icon or dropdown to pick the next folder to tag, you will already be in the correct directory and can move on to a new directory without touching the keyboard to move up or down in the directory structure.
Or you could have an open Explorer window and drag and drop the folders in question into the MP3tag window.
