Moved discussion from Export to Windows Media Playlist (.WPL)
Rename the file e. g. "export.mte.txt" and it should be allowed to upload the file.
DD.20090901.2053.CEST
Edit Florian: added link to original post.
This does not make a difference.
How can I contact the administrator for this forum to fix this?
Both simple cases work, see yourself:
Test_fo_uploading_MTE_file_into_forum_message.mte (28 Bytes)
Test_fo_uploading_MTE_file_into_forum_message.mte.txt (28 Bytes)
But uploading a mte or txt file containing such wpl XML code is forbidden.
"Upload failed. Please ask the administrator to check the settings and permissions"
DD.20090904.0641.CEST
Use code or codebox tags around your export code.
Put it in a zip archive.
