Hi, Newbie Here.
I've been using MP3Tag for quite a while but am probably only scratching the surface of what it can do.
However, I'm running up against a brick wall with this issue. I've searched the Forum, with no luck so far.
I want to auto-enter the "composer" details from a Discogs page into the appropriate tag.
I can successfully find the album details I want on the Discogs database, and can (usually) use the Discogs "Release id" number to ensure I've selected the right Discogs entry in MP3Tag.
But when I click "OK" and the tags are imported, it is not updating the Composer tag.
I'm not sure if the program can do this import?
I have also tried installing the "Pone" extension, but that only seems to improve the searching on their database, it doesn't seem to change the actual changing of the tags.
Am I missing something or barking up the wrong tree - thinking it can do something it was never designed to do?
