Wrong parsing the German letter "ß" and the French "é", "î"
What @Florian said. An "ß" showing up as "ß" is exactly what happens when UTF-8 data is erroneously interpreted as ISO-8859-1/windows-1252. Likewise, an UTF-8 "é" would appear as "é".
In the Apple/Windows case, an "é" should show up as an unaccented "e", followed by one or two garbage characters for the unrecognized acute.
Thank you, @squonk57, for the reminder.
It is true that Florian provided an excellent explanation...
I should have been more precise in my question.
Let me rephrase:
Given everything that has been discussed on this topic, does anyone have any ideas on how to help resolve the issue involving the "ß" character, which @MikeB mentioned in his post above?
I'm sorry, but you lost me here. Florian suggested a solution (use a different encoding, not UTF-8), and in the next post MikeB confirmed that it worked. What other problem do you mean?
The title L'été indien contains the special character é. However, this doesn't necessarily mean that the file uses UTF-8 encoding.
The same character can be encoded in different ways:
Encoding Representation of é
ISO-8859-1 One byte: E9
UTF-8 Two bytes: C3 A9
UTF-16 Two bytes: 00 E9 (Big Endian)
An older MP3 player might therefore display é correctly if it is encoded using ISO-8859-1, but fail when encountering the same character encoded in UTF-8.
Hexeditor examples for the Tag write options:
ID3v2.3 - ISO-8859-1
ID3v2.4 - UTF-8
ID3v2.3 - UTF-16
If you see this combination in a hex editor for
Ein kleiner weißer Schneemann
the encoding used is ID3v2.3-UTF-8 (if written from Mp3tag).
I've played with different combinations of properties and succeeded to reach the case when the same MP3-files, under ID3-tag 2.4 filled by Mp3tag 3.37 by converting file name to tag have a proper track name and the wrong-one:
The only difference is the initial file name, from which the tag has been generated:
  • La demoiselle de déshonneur.cool1.mp3 - correct
  • La demoiselle de déshonneur.mp3 - wrong
The conversion mask for both cases is %title%.
I still have to narrow my assumptions but I believe, I'm on the right track to localize the bug!
Given the following set of file names:
Applying convert Filename - Tag, I get:
As we may see, the correctly parsed are files:
  • La demoiselle de déshonneurb.mp3
  • La demoiselle de déshonneur.c.mp3
The rest have an issue. What's really strange for me, why is La demoiselle de déshonneur.c.mp3 parsed properly, while La demoiselle de déshonneur.a.mp3 does't.
What does lead .a to be parsed wrongly, while .c is OK?
Why the file name La demoiselle de déshonneurb.mp3 parsed correctly, while La demoiselle de déshonneur.mp3 doesn't?
Copy & paste the filename that works directly from Windows File Explorer here:
(Press F2 in Windows File Explorer, Ctrl + C and in Babelstone press Ctrl + V)
(press the Identify-Button)
Then copy & paste the name of the filename that doesn't work at Babelstone.
What difference do you see?
The correct filename (La demoiselle de déshonneur.c):
U+004C : LATIN CAPITAL LETTER L
U+0061 : LATIN SMALL LETTER A
U+0020 : SPACE [SP]
U+0064 : LATIN SMALL LETTER D
U+0065 : LATIN SMALL LETTER E
U+006D : LATIN SMALL LETTER M
U+006F : LATIN SMALL LETTER O
U+0069 : LATIN SMALL LETTER I
U+0073 : LATIN SMALL LETTER S
U+006C : LATIN SMALL LETTER L
U+0020 : SPACE [SP]
U+0020 : SPACE [SP]
U+00E9 : LATIN SMALL LETTER E WITH ACUTE
U+0068 : LATIN SMALL LETTER H
U+006E : LATIN SMALL LETTER N
U+0075 : LATIN SMALL LETTER U
U+0072 : LATIN SMALL LETTER R
U+002E : FULL STOP {period, dot, decimal point}
U+0063 : LATIN SMALL LETTER C
The wrong filename (La demoiselle de déshonneur.a)
U+0020 : SPACE [SP]
U+0020 : SPACE [SP]
U+0020 : SPACE [SP]
So, from the file name point of view, there is no difference besides U+0061 : LATIN SMALL LETTER A at the end.
That's not what you get, that's what your player makes of it.
  1. Read correctly
  2. Read correctly
  3. UTF-8 parsed as ISO-8859-1
  4. UTF-8 parsed as ISO-8859-1
  5. UTF-8 parsed as ISO-8859-2 :exclamation_question_mark:
  6. UTF-8 parsed as ISO-8859-1
Please show screenshots from the extended tag panel in Mp3tag.
Interesting, seems to be the same single character é (E9) in both cases (working / not working).
I think this is an Android bug, and they are heuristically trying to detect encoding rather than following the standard. Do you see this in other players as well? I think a few don’t use the default media store framework.
I observe this issue in the following media players:
Android 16, HyperOS 3.0.302.0
Correct:
Broken:
If you look at the content in the last two mp3 files itself (correct/broken) with a hex editor, what exactly do you see as saved character for é in déshonneur?
E9
or
C3 A9
or
00 E9
In the correct file it's C3 A9 in the broken it's also C3 A9.
If you want, I can share these two files and you can run more detailed checks, maybe there are some side effects, which affect the broken file.
Well, apparently Mp3tag read the name correctly.
Interesting blog post about Android and ID3 tags:
It's really interesting, although the post is almost 10 years old, so many thing could have changed since that time.
If both files - the correct one and the broken one - show the same content, that would suggest that the problem isn't with Mp3tag.
Unfortunately, as I don't have access to your phone or Android player, nor do I use the same transfer process, I won't be able to help you solve this mystery despite having access to the shared files.
Try with foobar2000, I think it uses its own library for reading.
In this app, all tracks are displayed properly!
