One more question please, is it possible to add a second sort order?
Like this:
Sort order 1: Date ascending (as it is now)
Sort order 2: Title ascending
Doubt it as you can't do it in the browser. Even file explorer can't behave like that. You only can sort one thing at a time.
Hi everybody!
Blockquote# INITIALKEY to Camelot notation. Please DO NOT change values (you can delete these replaces to get 'Dmin' etc.)
replace "♯" "#" # Fix
replace "♭" "♭" # Fix
replace ""A♭min"" ""01A""
replace ""G#min"" ""01A"" # SAME KEY #
replace ""E♭min"" ""02A""
replace ""D#min"" ""02A"" # SAME KEY #
replace ""B♭min"" ""03A""
replace ""A#min"" ""03A"" # SAME KEY #
replace ""Fmin"" ""04A""
replace ""Cmin"" ""05A""
replace ""Gmin"" ""06A""
replace ""Dmin"" ""07A""
replace ""Amin"" ""08A""
replace ""Emin"" ""09A""
replace ""Bmin"" ""10A""
replace ""F#min"" ""11A""
replace ""D♭min"" ""12A""
replace ""C#min"" ""12A"" # SAME KEY #
replace ""Bmaj"" ""01B""
replace ""F#maj"" ""02B""
replace ""D♭maj"" ""03B""
replace ""C#maj"" ""03B"" # SAME KEY #
replace ""A♭maj"" ""04B""
replace ""G#maj"" ""04B"" # SAME KEY #
replace ""E♭maj"" ""05B""
replace ""D#maj"" ""05B"" # SAME KEY #
replace ""B♭maj"" ""06B""
replace ""A#maj"" ""06B"" # SAME KEY #
replace ""Fmaj"" ""07B""
replace ""Cmaj"" ""08B""
replace ""Gmaj"" ""09B""
replace ""Dmaj"" ""10B""
replace ""Amaj"" ""11B""
replace ""Emaj"" ""12B""
replace ""G♭min"" ""11A""> Blockquote
I want to get my "Classic Key" TAG back!
Best regards!
Delete all of that code or place a # at the beginning of each of those lines.
Hi, everybody!
Please help!!!
2020-06-26_140700 (Másolás)
Answer in this thread.
Hi @stevehero beatport classic (and beatport pro) will shutdown soon.
Are you still working on the v5 of your script?
Kinda. It's more or less written for the release scripts. When that dark day comes I'll probably knock it out. Just too much on my plate at the minute to get to it.
Thanks for the answer @stevehero.
They said that it is going to shut down somewhere around the fall and this was two months ago, so i assume that we are pretty close to it!
I did get that in an email alright. Not to worry. I'll get on it when that comes as I don't have time.
1st Thank you stevehero for all the work past years to keep that alive. i use it since years and almost always worked well. since yesterday i get a 404 error when using the script. worked well before. i think they are changing now to the new store. so as always wait for a few days guess :slight_smile: hope your v5 is soon here.
The regular beatport website is surprisingly easy to parse. I already made my own websource that does what I want it to do. This isn't my thread though.
EDIT: I wrote this beatport websource from scratch. I tried to keep it simple (less than 200 lines total). The only issue I see is that a blank [remixer] field is filled with "[none]". A custom action to replace [none] in the REMIXER field with a blank should work out or simply comment out the remixer section in the src file. I ask for no money. If anybody wants to chip in a buck or two, please donate it to mp3tag* instead (find the donation link on its main page). Just let me know how it works out for you.
B&eatport#&1 &AlbumArtist + Release.src (4.4 KB)
*I'm not affiliated with mp3tag in any way other than being a fanboy who really enjoys using the program.
Nice, can you share it if possible? If you don't wanna hijack the post you can pm me. I am a typical end user and have no clue what to do to fix. I tried in the script to manually change the adress to beatport.com but no luck.
I am a soundguy not script and cod3 guy :laughing:
I also tried manually and no luck :grin:
Hello, maybe you could open a new thread for sharing it with us :smiley: Thank you
See my beatport source file here: Beatport.com WSS by stevehero [Release, Single Track & Artwork tagging]
I'd like a little bit of respect shown. It hasn't been a day and people are posting their versions in this thread. I've been updating this for close to 10 years with a couple of donations a year but you can't wait a few days for me to get this fixed.
You can also remove my name from any modifications you do to it. Filename and inside the script.
Steve, never mind! We are all waiting for your new version. Search by "artist - title" is very necessary
I'll try finish it off before the weekend.
Awesome. Many thanks. Just sent you 5 Euros
