Awesome! Just donated you for a beer :smiley:
I've no pubs to spend all this dosh in now. Thanks for those donations. The new script for album parsing has been more or less done a few months but I didn't get round to testing it. The single track version has yet to be started.
I didn't use anything from your script. Like I said, I wrote it from scratch since the beatport page is pretty easy to parse. A few asked for it after I mentioned the parsability of the page and I obliged.
need replace "REMIXER" to "MIXARTIST" and remove [none]
Hey, just tested your script. It works but some things are missing that are important to me (catalogue id after album, date in dd. Mm. Yy format,..) . So i wait for steve because i like my collection all the same. Thanks for your effort.
RELEASE Direct by &WWW(URL) [by stevehero™] still working
just add to HOSTS file line
208.92.200.1 www.beatport.com
Thanks for the quick fix while I get this done.
nice. thx. it now finds the list to choose with release and after choosing one i get error 302: found!
and after selecting i get this
302
can someone please enlightewn me what to do?
need search in browser, then insert url - e.g. http://www.beatport.com/release/desiderati-4-4/3137129
end use only script "Direct by &WWW(URL)" other scripts not working
ahh, now i got it. many thanks.
Here's the first draft. I could spend days looking for bugs so I'll hand it over to you lot so you can let me know what releases are causing issues.
Here's what's left to do:
# Leading zero user option on track no.
# TRACK/TOTALTRACKS to do. e.g. 1/10, 2/10, 3/10 etc.
# BEATPORT_ARTIST_URL has double // at the end if multiple artists.
# Plus additional bug checking.
This doesn't include the single track scripts yet or direct scripts. Just searching the releases and artwork.
Is this something you lot use? (the single track scripts) I'm finding very little use for it myself atm.
The scripts included here are (2 artwork scripts and releases ones):
  • Beatport by &stevehero v5.0#Artw&Ork Search by (Album)Artist + Release
  • Beatport by &stevehero v5.0#Artwork Search by Release
  • Beatport by &stevehero v5.0#RELEASE Search by &Artist
  • Beatport by &stevehero v5.0#RELEASE Search by &Directory
  • Beatport by &stevehero v5.0#RELEASE Search by &Filename
  • Beatport by &stevehero v5.0#RELEASE Search by (Album)Artist + &Release
  • Beatport by &stevehero v5.0#RELEASE Search by (Album)Artist + Release (150 Results)
  • Beatport by &stevehero v5.0#RELEASE Search by (Album)Artist + Release (Sorted by Date Asc)
  • Beatport by &stevehero v5.0#RELEASE Search by (Album)Artist + Release (Sorted by Date Desc)
  • Beatport by &stevehero v5.0#RELEASE Search by (Album)Artist + Ti&tle
  • Beatport by &stevehero v5.0#RELEASE Search by Relea&Se
  • Beatport by &stevehero v5.0#RELEASE Search by Release (150 Results)
  • Beatport by &stevehero v5.0#RELEASE Search by Titl&E
v5_beta.zip (22.1 KB)
Wow, you are awesome. Thanks a lot. Will test today.
Personally i never used direct and single track. I find all infos with the release most of the time. If i find nothing it is not on beatport 99% of the time (early releases from bandcamp, promos)
Thank you @stevehero. :clap: :clap: :clap:
I'll give it a look tomorrow!
Thank you very much.
I only use "Search by (Album)Artist + &Release", this brings up this error here:
"Search by Artist" only shows a list of 25 releases maximum, not enough for this one for example:
"Search by Release" works.
Could YADG be of any use for your script?
Personally, I only use single track script! I would really like it to work too!
Снимок экрана 2020-10-29 в 11.48.44
Connect error...
Please post links to the release urls that are causing the issue.
There are (150 Results) scripts in there to get around the limit if you want more searches.
You may need to update your mp3tag.
It works. But all tracks with titles (Original Mix) and (Extended Mix) contain 404 error ...
Remixes and dub mixes are searched normally.
P.S. i use search by filename.
Still need the URL of the release you're trying to parse.
Searching for this 4NYON3 - Rotten Humanity EP NRDR112 with Directory, returns a 404 error, when i remove the artist part 4NYON3 it works!
https://www.beatport.com/release/rotten-humanity-ep/3113549
Same problem with this one Alan Fitzpatrick & Reset Robot - The Cosmic Opera WATB057
  • Alberto Lencina - Trapped In Me The Album MNR212
Something else that i observe is that when i use the ctrl+shift+I to use the latest used tagsource it asks me to "confirm" the Directory, if i am correct this was not happening with v4.4.
