Update 3.9:
NEW:
You can now choose between different formats of the tracknumber. You can also choose more than one format and write it to different tag fields.
These are your possibilities:
Counting Numbers:
1, 2, 3, ... This is the standard output for Mp3tag web sources scripts as you have got it until now. You will still get this into the %track% field if you don't put "track" into one of the following fields.
01, 02, 03, ... = DISCOGS~TRACK NUMBER WITH LEADING ZEROS FOR 01-09.
Counting numbers with leading zeros for tracknumber 01-09. No leading doubles zeros if more than 99 tracks: ... 97, 98, 99, 100, 101, 102, ...
01/10, 02/10, 03/10 ... = DISCOGS~TRACK NUMBER WITH LEADING ZEROS / TOTALTRACKS
Counting numbers with leading zeros for tracknumber 01-09 combined with the total tracks as found at discogs. This does only work up to 99 tracks. After this it continues with normal numbers: ... 97/120, 98/120, 99/120, 100, 101, 102 ...
Track Positions as written on discogs pages:
- exact the same as you see it on the page =
DISCOGS~TRACK POSITION AS ON RELEASE PAGE
- only written when discogs has something different as standard counting numbers, combinations with discnumber appear without discnumber = DISCOGS~TRACK POSITION (SAME AS BEFORE VERSION 3.9, NOT ALWAYS WRITTEN)
This is the same as until now in DISCOGS_TRACK POSITION. I would have left it away if I would present the script for the first time, but I don't want to delete things which you are used to. So this will have the same value (= mapped tag-field) in your option file as you had in DISCOGS_TRACK POSITION before. Basically DISCOGS_TRACK POSITION is just renamed to avoid confusion with all the new track fields. I would not map this to "track" because i stays empty at normal CD releases.
Three more track position field, whith speciall functionality. You can map this fields to the same fields as above. They will only be written if they make sense. Otherwise your standard track field from above is written.
- 01, 02, 03, ... 01, 02, 03, ... =
DISCOGS~TRACK_ONLY FOR MULTI DISC CDS: NUMBER STARTING FROM 01 AGAIN FOR EVERY DISC
Tracknumbers come here always with leading zeros for 01-09 and are set back to 01 for every disc.
This is only written for discogs releases which are mediatype CD or CDr and only if these have more than one disc and only if these are proper numbered at discogs with the discnumber as a part of the track position. If you want to use this I would advice you to use DISCOGS_DISCNUMBER, too. Because only in comination with that field it makes sense to start from 01 for every disc.
101, 102, 103, ... 201, 202, 203 ... DISCOGS~TRACK_ONLY FOR MULTI DISC CDS: NUMBER COMBINED WITH DISCNUMBER
Same as above, but combined with the discnumber. So you don't need DISCOGS_DISCNUMBER in an extra field if you have that (but you can, if you want).
This field has an extra option: TEXT OPTION: COMBINE DISC&TRACKNUMBER WITH:
Whatever character you put into that option field will appear between disc- & tracknumber. So you can have 1.01 / 1-01 / 1 01 / 1_01 / 1001 / ... whatever you want. If you put "no" into this field you will get 101
a1, a2, b1, b2, ... = DISCOGS~TRACK_ONLY FOR VINYL & CASSETTES: POSITION AS ON RELEASE PAGE
This is only written for discogs releases which are mediatype Vinyl, Cassette, Acetate, Shellac, Microcassette & Lathe Cut. So all types which have two sides and where the numbering at discogs typically has letters for each side. It gives always the same out put as seen on the discogs page, so you can also have A1, A2, AA1, AA2 or other more uncommon counting systems.
And finally, you have now also the option to leave %track% blank if you want: DISCOGS~TRACK_OPTION: LEAVE TRACK EMPTY? = yes / no
NEW:
You have a new options in which you can state if you want to write DISCOGS_DISCNUMBER and DISCOGS_TOTALDISCS if there is only one disc: OPTION: DISCNUMBER: WRITE DISCNUMBER FOR SINGLE DISC RELEASES and OPTION: TOTALDISCS: WRITE TOTALDISCS FOR SINGLE DISC RELEASES
NEW:
You have now the option if you want to treat releases with mediatype File 1 or 0 discs. Regardless if Discogs says 10 x File, 20 x File or just File. OPTION: TOTALDISCS: COUNT DIGITAL RELEASES (FILE) AS 1 (YES) OR 0 (NO) DISCS
NEW:
If you put the same value into DISCOGS_DISCNUMBER and DISCOGS_TOTALDISCS (= map them to the same tag fields), they will be combined in that field by an slash (/). So you can have discnumbers like 1/4, 2/4, 3/4, ...
NEW:
You can now change the field in which the track tiles are written or leave the title away like all other fields: DISCOGS_TITLE = title / no / whatever you want
NEW:
The original track position as written on the discogs page is now always displayed behind the length of the tracks in the "Adjust tag information" dialog. This has no effect on the written tags, it's just for better overview for albums where the tracknumbering is not straight forward.
NEW:
In the searchbox title appear of all "search" scripts appears now the following message: Add &page=2 For Next 20 Results
This is just a little reminder for what you can do if the release you are searching doesn't appear in the list of the first 20 results. Append &page=2 to the search querry, and you will see the next twenty results. And &page=3, &page=4, page=5... for the next 20 after that.
FIXED:
DISCOGS_TOTALDISCS has been simply the number at "Format: ..." at discogs. If the format was "2 x CD, Compilation; CD, Compilation, Mixed", totaldiscs was 2 instead of three.
For format "CD, Compilation; CD, Compilation, Mixed" it was an empty output. There was also no summation for numbers, for Format "2 x CD, Compilation; 2 x CD, Compilation, Mixed", the output was "2, 2". And File release were treated if each file was an extra disc (see new option above).
Now all these things are proper regognized and summarized. And the pseudo discogs mediatpes "Box Set" and "All Media" are not counted at discs.
FIXED:
Discnumbers are now also proper recoginzed if they are written with text in front of the number at the discogs page. Like: CD1-01 / CD1 01 / Disc 1 1
FIXED:
If multiple artists of one track are seperated with a comma at discogs, there has been a space in front of the comma at the script. This is fixed now.
FIXED:
The script had a little problem at displaying the search results with some releases which have quotationmarks in the title. This is fixed now.
FIXED:
The new discogs series do not always have a catalog#. In those cases you could have got results which ended with ", " for the catalog# tag (depening on your settings). This is fixed now.
FIXED:
Several tag fields could not be written when another field was set to "no". This is fixed now. The field with problems were:
DISCOGS_RELEASE URL could not be written without DISCOGS_RELEASE ID
DISCOGS_ARTIST could not be written without DISCOGS_ALBUMARTIST
CHANGED:
The tag fields DISCOGS_RELEASE_ID (DISCOGS_RELEASE ID) and WWW (DISCOGS_RELEASE URL) appear now at the end of the tag fields list in the "Adjust tag information" dialog. That gives a better overview of the more relevant other tag fields without the need to scroll down.
CHANGED:
A purely technical change which makes the scripts smaller and so a little bit faster. I changed the way the tag fields are treated which you set to "no". The coding for these fields doesn't appear in the scripts now.
This is a larger update with many new possibilities. I have done lots of test with different settings and on different discogs pages, and I hope that I have found and solved most discogs problems and script errors.
Especially the modifications on %track% and %title% caused lots of troubles, since this is originally not provided for Mp3tag web sources scripts.
However, if you find some problems with certain discogs pages or get errors from conflicting settings in the settings mp3 file, please tell me.
All new fields are set to "no" after the update because I don't like to change the way you are tagging without asking. You have to make the changes in the setting files yourself.
- download in the starting post -
