Really? It should not. At TRACK & DISCNUMBER, these are the two crucial lines for your problem:
Trackposition (as written on discogs page): >
- write Trackposition only for Vinyl & Cassettes >no
The first line has to be empty after the > character.
The second line can have yes or no. Try no, but it should not matter if the first line is empty.
I don't know what kind of update you are talking about. There are there things at the script which can be called update.
1.) When I make a new script version, you have to update the export and actions files. For that, download the new package and move the files into the Mp3tag profile folder. By replacing the old files with the new files, you update the export and action files.
That works in the new script as it has worked in the old one before.
2.) When I make a new script version, you have to update the your settings files. With this update, I can write new options and tag fields into the setting file already stored at your computer.
In the old script there was an action for you to do this. (Discogs Pone>Update Settings MP3 File...). The action itself was renewed by overwriting the old action file as described above.
In the new script, I haven't made that update action yet. It's more complicated because of the new multiline structure of the setting file. That's why you need a new setting file and change the settings again as you like it. I will include a update action for the setting file when the discogs pone 4 script gets new options.
3.) When I make a new script version AND whenever you want to change something in the settings of your script, you have to update your web script files. This happens with the Discogs Pone>Create Scripts... action. That works in the new script as it has worked in the old one before.
So after you make changes in the settings mp3 file, click only the Discogs Pone>Create Scripts... action to have the changes transfered to the web sources files.
The Discogs Pone>Update Settings MP3 File... action was only for for the version update as described in 2.). It was never necessary for your own changes in the settings file as described in 3.)
Why does it go back? Where did you change it? It should not.
You can use any tag field you like.
Note that you choose the tag field for the Credits section in the ARTIST NAMES section of the setting file. This might be confusing. There you can choose a tag field for Extra Artist - Album Credits - Primary Name and/or another tag field for Extra Artist - Album Credits - Name Variation.
In the CREDITS; NOTES; IDENTIFIERS; COMPANIES section of the setting file at Combine Credit fields with other fields:, you can only contol if the credits stand alone (>no) or come with headline ("Credits:") and a trailing empty line (>yes).
sure. just write the date into the YEAR tag-field at the YEAR & DATE section:
Year: >
Date: >YEAR
Was it that what you want?
If you want both tag fields in a formated way, you can use the Additional Web Sources Script Code for the standard scritps: Additional Web Sources Script Code for the standard scritps:
part in the OTHER FIELDS & OPTIONS section. You can put some web script command between and . If you want the same format for both fields, you can simply use
outputto ...
sayoutput ...
If you want different formats, you would have to put the whole code to get the second field there, starting with
findline "<>" -1 1
to get to the begin of document and than parsing for what you want. I guess you can easily do that as an expericenced mp3tag web scripts writer.
WORKING CODE in OTHER FIELDS & OPTIONS under Additional Web Sources Script Code for the standard scritps:
outputto "YEAR"
gotoline 1
findinline "\"released\":" 1 1
if " \""
gotoline 1
regexpreplace ".*\"released\": \"([^\"]+)\".*" "$1" # Returns '2012-02-12' '2012-12' or '2012'
regexpreplace "^(\d\d\d\d)$" "$1-00-00" # Returns 'YYYY-00-00' if only the year resides
regexpreplace "^(\d\d\d\d)-(\d\d)$" "$1-$2-00" # Returns 'YYYY-MM-00' if only the year resides
sayrest
endif
#<CODE END> </strike>
I can't seem to get this to work. I thought it did last night but it removes the track names, track no's and such. So I changed the
- date format: >YYYY-MM-DD
and pasted the same code only outputted it to the YEAR field under Additional Web Sources Script Code for the standard scritps:
I thought this would work but same problem arose. How do I get around this. Sorry I'm just not too familiar with your script.
Fixed: Bug at track numbers at ill formated discogs pages.
Fixed: Bug at track numbers at releases with only one track
When updating from 4.unfinished to 4.unfinished 2, you don't need to make any changes in the Discogs Pone 4 Web Script Settings.mp3 file. Keep your old one, delete the new one.
Fixed: Bug with userdefined additional web sources script code.
When updating from 4.unfinished x to 4.unfinished 3, you don't need to make any changes in the Discogs Pone 4 Web Script Settings.mp3 file. Keep your old one, delete the new one.
Download now in the starting post -
@ Stevehero:
Thanks for spotting the bug.
The following code gives you a YYYY-MM-DD formated year field. I included year 0000-00-00 and date 0000 for completly missing release years. I'm sure you know how to change this.
I'm just wondering if you plan to do an option to leave the TRACK like 01/13, 02/13, 03/13 etc as you had in the old version instead of 01, 02, 03. And have you any intention to add a leading zero option to DISCNUMBER + TOTALDISKS and to format the TOTALDISKS like 01/02 which is displayed as see attached in iTunes.
By the way all the leading zeros work in iTunes including TRACK, DISCNUMBER + TOTALDISKS.
It is already there. Look at the options in the TRACK & DISCNUMBER section:
Tracknumber: >TRACK
Totaltracks: >TRACK
leading zeros for tacknumbers >yes
disable leading zeros if less than 10 totaltracks >yes
If you choose the same tag-field for Tracknumber: and Totaltracks: you get 01/13, 02/13, 03/13, ... or 1/13, 2/13, 3/13, ...
You can also choose different tag-fields for those.
The leading zeros depend from the third line (>yes or >no).
In the fourth line you can choose if you also want leading zeros for less than 10 tracks (as the Mp3tag Track Wizard does), or if you want to disable that.
The same works for Discnumber, you can choose the same tag-field for Discnumber: and Totaldiscs: and they will get combined with a slash.
Discnumber: >DISC
Totaldiscs: >DISC
No leading zero options there, as ten or more discs are very rare.
Sorry I didn't make myself clear. I was looking for the following outputs.
TRACKNUMBER: 01/13, 02/13 etc TOTALTRACKS: 13 DISCNUMBER: 1/1 TOTALDISKS: 01 (Its okay, I can deal with this being a '1')
With the options you have it's only possible to go with one or the other. I was nearly sure there was an option in your last v3 scripts to append the TRACKS/TOTALTRACKS + have a TOTALTRACK output at the same time.
Yes, I had this in the old script. I didn't think anybody would use this to get TOTALTRACK into two fields, it was rather due to the organisation of the options in the old setting file.
If you want TOTALTRACKS and TOTALDISCS in extra tag fields, you can try to add some more code to the Additional Web Sources Script Code for the standard scritps: at OTHER FIELDS & OPTIONS. Both things are rather complicated and long, but you could simply copy them if you set the script up to write seperate fields for the total values.
Maybe I will include this as an option again, but rather not. These things make the settings more confusing for the user and I can't see any sense/use in having that information in two tag fields.
Got it all configured correctly. Thanks for the guidance.
The v4 seems to simplify everything once you understand it logic
Don't know why, but when I tagging this release http://www.discogs.com/release/147175 duplicated tags like "publisher" or "catalog" have in one field with "//" separate. I deleting all tags and retagging but it doesn't work.
Other releases was tagged ok.
\\ is Mp3tag's character to write and display multivalue tag fields. However, multivalue tag fields can't be written diretly by Mp3tag's web sources scripts.
Read here how to deal with them: [WS] Discogs (pone mod)
If you don't want mutlivalue tag fields there, open the LABEL & SERIES section in the settings file. You see there the following Label and Label # (=Catlalog #) and for Series and Series #_
if more than one label:
only the first >no
multivalue tag field >yes
list of names >no
seperating characters used in list >,
In the lines 2-4 there, write ">yes"in one of the lines and ">no" in the other two lines. If you choose, "list of name", in you can choose the seperatin character in the following line. Make sure that you use a trailing space there after a comma or similar, e.g: ">, " or ">; ".
There are similar options at the GENRE & STYLES and ARTISTS NAMES section
hello Pone,
sorry for my late answer.
just discovered that i still used v2.49b.
installed the new version and it works flawless now.
sorry for the confusion and thanks again for your great support.
cheers,
timo
I want action group to make it look like this: --Format Value (without WWW) --Update tags with PoneScript (by WWW tag) <==HOW DO THIS? --Split field by seperator (\\)
Thanks for the script pone, you've made my music catalog look so good
Before the last update I seemed to have this working, but can't seem to get it working now so:
for the CATALOG#, I just want it sitting in a pair parenthesis e.g. (AG005), and also this CATALOG# to be inserted after the ALBUM title e.g.
Fall / Suspended Animation (AG007)
Again I had this working before the last update, but now can't seem to work it into the script...thank yoU!
