I'm just starting to get the hang of using this program, so perhaps I'm doing something wrong, but...
Using the Magistrix source for lyrics, is it not possible to get more than the first fifty results? For instance, I was trying to snatch the lyrics for "Awake" by Josh Groban, but the first fifty results end in the D's.
Yes the limit currently is 50. The site allows 100 maximum.
You can change it to 100 if you open the file in a text editor and search for pagelen=50 and change it to pagelen=100
I can also make a version that searches by title and artist which should give more accurate results.
The script for Sing365.com doesn't seem to be working anymore. I removed the :8080 part from the search URL, but... whenever I get results, it says "UNSYNCEDLYRICS "
I'm apparently not understanding how this one works, or I've got something setup wrong...
I've installed the Sing365 .src so far and added UNSYNCHEDLYRICS to my tag panel but when I use the web source I only get the very first line, usually the writer credits, not the full lyrics.
I can't seem to get any results from either sing365 or Magistrix anymore. Actually, none of the lyrics sources available here on the forum seem to work for me at all...
I'm not sure how the scripting works, but is it possible to be able to grab lyrics from http://www.ohhla.com/? There is no search function, so perhaps it is not doable. However, if it is possible, I would greatly appreciate it.
Thanks for all of your work.
LyricsWiki seems to no longer support Web Source Scripts:
"Unfortunately, due to licensing restrictions from some of the major music publishers we can no longer return lyrics through the LyricWiki API (where this application gets some or all of its lyrics).
The lyrics for this song can be found at the following URL:
some url
(Please note: this is not the fault of the developer who created this application, but is a restriction imposed by the music publishers themselves.)"
Currently I'm having no luck with any of the available lyrics script.s
Unfortunately the darklyrics script is not working properly...
It is a really helpful script and it works perfectly sometimes, for example the band Blind Guardian, but with others it doesn't, like Grave Digger or Annihilator, even though the lyrics are on the website and when I click on "This album on Darklyrics" it redirects me to the correct page. It shows under additional information: UNSYNCEDLYRICS .
