something like get a array of selected song names and artists and do a loop of searches.
I wrote a script to import lyrics from some sites, works fine.
but some things is just don't clear to me, because I edited others scripts.
I'm a programmer, but I don't really get the whole idea of this scripting language, is not procedural, doesn't seems like goto, nether any other that I know. I'm not sure if the statements are actually like writting to a buffer or just discarding text.
what is that for?
[ParserScriptAlbum]=...
[ParserScriptIndex]=...
outputto "coverurl" this I understands, I guess...
theres any way of do a search, get the lyrics, and then search other url and get the cover and output both lyrics and cover in a single script run?
I know it's a lot of questions, I not found any useful reference on this forum and now Im feeling very dumb, if can anyone clarify some of these questions, I appreciate.
The script extracts only lyrics from the Rap Genius active "lyrical definining" engine. There will be no explinations to the lyrics. I believe this is what your looking for as rap genius isen't really a lyrical database. They define it at as,
"Rap Genius is your guide to the meaning of rap lyrics (basically the internet version of the nerd-ass “rap dictionary” dorm-mate you had in college).
You can listen to songs, read their lyrics, and click the lines that interest you for pop-up explanations – we have thousands of canonical rap songs explained (2Pac, Notorious B.I.G., Jay-Z – even the beginning of the Torah..)
Our aim is not to translate rap into “nerdspeak”, but rather to critique rap as poetry.
I don't listen to much rap but this site is really something special for those die hard hip-hop enthusiats....
Though they are pretty rare on tracks they ocassionally appear and could be covered
Additionally I think the $caps2() function would be better because sometimes mid-word-capsed characters are brought down to normal case and it can't be found on lyricwiki. Will try this in my script for some time and see if it gives problems
Also solves problems with mp3tag converting characters to normal case when they are following a special character
How do i install these scripts? i put the src files in my sources folder where Mp3tag was installed, however, when i open the program and go to Tag Sources, i don't see anything about lyrics, i see the usual Amazon, FreeDB etc.
Can anyone help me install the lyrics script please
Edit: I have put these in my Program Files folder, or are the scripts to go on my APPDATA folder?
You have to install them in the APPDATA folder, sorry, great scripts guys, my appreciation is endless.
SongMeanings did a long overdue overhaul of their website so now the old script doesn't work anymore. Here's an updated version: http://ubuntuone.com/1MN8S8ngrN4hbyZqdQHJvi
I created an account mostly just to say thanks for the lyrics download scripts. I used to have something in Mediamonkey that would let me do batch downloading, but I can't remember what it was called and I can't find it yet after reinstalling Windows. A Google search had me stumble across this thread, and I already had mp3tag installed, so I tried these scripts. The Dark Lyrics and Lyrics Wiki scripts posted by Dano work fine. I can't do batch tagging with Lyrics Wiki, but Dark Lyrics lets me tag an entire album at once. I'm satisfied with both. I didn't try Magistrix and his Song Meanings didn't work and I think the Metro may not have worked either, but the two I was most needing were Lyrics Wiki and Dark Lyrics anyway. Also, the updated Song Meanings script right above my post by InspectorMustache works fine when doing one at a time. The Lyrics.com script by tbum20 four posts up from mine didn't work. Overall though, I'm happy with what I have and wanted to thank you all. Oh, mp3tag has been really helpful as well. I like to do my tags manually and have control over them. Thanks for the program.
Problem with tag (') character:
LyricWiki (and probably other sites) fail to serve the reuest if it includes a tag charcter.
When searching in the site the tag is replaced with %27 - i.e.: http://lyrics.wikia.com/U2:Tryin%27_To_Thr...round_The_World
I tried to modify the lyricwiki script in the following manner: Original:
I found https://github.com/kenshiro-o/RapGenius-JS/ for those looking to extract lyrics from Hip Hop songs. I don't know how to use it, I've installed it but how do I integrate it with Mp3Tag?
I decided to make a new post with the Genius script since the site was relaunched and now covers so much more than Rap Lyrics, more information below:
On July 12, 2014, reflecting its recent expansions and growth into a platform, Rap Genius re-launched as simply Genius which expanded the site into much more than Rap lyrics. It now covers much more than we are interested in with lyrics but at the same time the lyric database is MUCH deeper and now covers all genres. The main site is simply Genius com and has subchannels for other genres along with annotations of much more which is of no importance for the subject this crowd. I have updated the script to search the entire Genius lyrical database which obviously includes the Rap channel of the new genius site.
RapGenius
I noticed the RapGenius script was not working and have fixed it. I don't actually use all the scripts and randomly just checked this one, if any script stops working just make a post.
