Hi @waterproof ,
that's odd... so please don't mind me asking some obvious questions (beyond "Have you tried turning it off and on?" which unfortunately can't apply here).
Do you have the latest version of the script? (see my last message with version 2022-11-06 above) I'm asking because there is no killtag command on line 96... I'm not 100% sure the line number is reliable in error messages but who knows.
Which version of Mp3tag do you have? "Killtag" is definitely an existing command (cf Developing Tag Sources – Mp3tag Documentation) but perhaps it was added in a version more recent than yours... I had version 3.18 when I worked on the script in November, now I got 3.19 and it's still working for me.
If 1) and 2) check out, do you mind saying which album you searched for so I can try to reproduce the issue? With all the different types of albums, I may have missed a case during my last fixes.
Thanks @Florian!
In the meantime @waterproof, I tried using RegexReplace as an alternative. I did it quick and dirty so it might not be full-proof, but if it unblocks you until the next Mac update... try replacing the whole source code with this:
# Mp3tag (v2.40+) parsing for RateYourMusic
# created by dano
# This file should be in your sources dir.
# On Windows XP it's C:\Documents and Settings\*username*\Application Data\Mp3tag\data\sources
# -> DO NOT COPY/MODIFY AND REDISTRIBUTE THIS WITHOUT PERMISSION <-
# update for RYM 2022 by nathbot
# v5.0
# v5.1
# add RYM primary genres, secondary genres, description; fix for Various Artists
# 2022-11-06
# Fix details import when Released date has a year with no link
# Integrate fix from User_name on separate RYM primary/secondary genre tags
# Fix bug when getting artists in Various Artists releases
[Name]=RateYourMusic
[BasedOn]=rateyourmusic.com
[IndexUrl]=http://rateyourmusic.com/httprequest?searchterm=%s&type=l&page=1&action=Search&rym_ajax_req=1&request_token=
[AlbumUrl]=http://rateyourmusic.com
[WordSeperator]=+
[IndexFormat]=%Cover%|%Artist%|%_url%|%Album%|%Year%|%Type%|%Publisher%|%Description%
[SearchBy]=%album%
[Encoding]=url-utf-8
[ParserScriptIndex]=...
# I N D E X
# debug "on" "debug_RateYourMusic_search.out" "10"
# debugwriteinput "RateYourMusic_search.html"
findline "<table><tr class=\"infobox\">"
do
# Cover
findinline "<table><tr class=\"infobox\">"
moveline 1
findinline "<td class=\"page_search_img_cell\">"
if "<div"
moveline 2 1
findinline "data-src=\"" 1 1
if "//"
say "Yes"
moveline 4 1
endif
else
moveline 2 1
endif
say "|"
# Artist
# Always get artist name in latin characters
RegexpReplace "(<a [^\<\>]+? class=\"artist\">)([^\<\>]+?<span class="subtext">\[)(.+?)(\]</span>)" "\1\3"
# In case there are two artists, merge them into one name
RegexpReplace "(class=\"artist\">[^\<\>]+?)</a> / <a [^\<\>]+? class=\"artist\">([^\<\>]+?</a>)" "\1 / \2"
findinline "class=\"artist\">"
sayuntil "</a"
say "|"
# URL
GoToChar 1
findinline "<i><a"
findinline "href=\""
sayuntil "\""
say "|"
# Album
GoToChar 1
findinline "searchpage\">"
sayuntil "<"
say "|"
# Year
moveline 2 1
findline "width:4em;\">"
findinline ">"
sayuntil "<"
say "|"
# Type
moveline 2 1
findinline ">"
sayuntil "<"
say "|"
## Publisher
moveline 2 1
sayregexp "(?<=\"label\">)[^<]+(?=<)" ", "
say "|"
## Desc
moveline 1 1
findinline "</td>" 1
if "<tr><td colspan=\"5\">"
RegexpReplace "</?b[^>]*>" ""
RegexpReplace "</?span[^>]*>" ""
RegexpReplace "</?a[^>]*>" ""
gotochar 1
findinline "colspan=\"5\">" 1 1
sayuntil "</td"
endif
saynewline
moveline 1 1
moveline -1 1
findinline "</table></td></tr></table></td></tr></table>" 1 1
# unspace
while " <br /><table>" 100
[ParserScriptAlbum]=...
# A L B U M
# debug "on" "debug_albumdetails.out" "10"
# debugwriteinput "RateYourMusic_albumdetails.html"
# Album
outputto "Album"
findline "<div class=\"release_page\" itemprop=\"mainEntity\" itemscope itemtype=\"http://schema.org/MusicAlbum\">"
findline "itemprop=\"name\""
findinline "<meta content=\""
sayuntil "\""
# RateYourMusic Album URL
outputto "RateYourMusic Album URL"
say "http://rateyourmusic.com"
findline "itemprop=\"url\""
sayuntil "\""
# RateYourMusic Cover
findline "alt=\"Cover art for "
moveline -1 1
findinline "src=\""
outputto "Coverurl"
say "http:"
sayuntil "\""
# RateYourMusic Artist URL
outputto "RateYourMusic Artist URL"
gotoline 1
findline "itemtype=\"http://schema.org/MusicGroup\">"
findinline "itemprop=\"name\" href=\""
sayuntil "\""
gotoline 1
findline "<table class=\"album_info\">"
# Year
findline "<th class=\"info_hdr\">Released"
findinline "<td colspan="2">"
findInLine " "
findInLine " "
OutputTo "YEAR"
SayNextNumber
# Full date
findline "<th class=\"info_hdr\">Released" 1
# ## Remove tags in date
# ### change order to year-month-day
Replace " " " "
RegexpReplace "([0-9]+) ([A-Za-z]+) ([0-9]+)" "\3-\2-\1"
# ### replace month string by numbers
Replace "January" "01"
Replace "February" "02"
Replace "March" "03"
Replace "April" "04"
Replace "May" "05"
Replace "June" "06"
Replace "July" "07"
Replace "August" "08"
Replace "September" "09"
Replace "October" "10"
Replace "November" "11"
Replace "December" "12"
# ## Add leading zero to days 1-9
RegexpReplace "([0-9]{4}-[0-9]{2}-)([0-9][\s]*<)" "\10\2"
OutputTo "FULLDATE"
findinline "<td colspan=\"2\">" 1
SayUntil "</td>"
# Genre(s)
gotoline 1
findline "class=\"release_genres\""
# ## Primary genres
findline "<span class=\"release_pri_genres\">"
OutputTo "GENRE"
sayregexp "(?<=/\">)[^<]+(?=</a)" "; "
# ## Secondary genres
findline "<br />"
findinline "<br />"
if "<span class=\"release_sec_genres\">"
findline "<span class=\"release_sec_genres\">"
findinline "<span class=\"release_sec_genres\">"
if "<a "
say "; "
endif
endif
# Separate RYM Primary Genre tag (courtesy of User_name)
gotoline 1
OutputTo "RATEYOURMUSIC PRIMARY GENRE"
# Note from nathbot: here the ";" separator can be changed to whatever you prefer. For "\\", enter "\\\\".
sayregexp "(?<=/\">)[^<]+(?=</a)" ";"
# Separate RYM Secondary Genre tag (courtesy of User_name)
findline "<br />"
findinline "<br />"
OutputTo "RATEYOURMUSIC SECONDARY GENRE"
endif
# Descriptors (courtesy of User_name)
gotoline 1
OutputTo "RATEYOURMUSIC DESCRIPTORS"
findline "<span class=\"release_pri_descriptors\">"
Replace "<span class=\"release_pri_descriptors\">" ""
Replace ", " ";"
SayUntil "</span>"
gotoline 1
findline "<span itemprop=\"byArtist\""
# Artist and tracks
findinline "class=\"artist\""
movechar 1
if "Various Artists"
# Various Artists
outputto "ALBUMARTIST"
sayuntil "</a"
# Tracks
gotoline 1
findline "section_main_info section_outer"
findline "show-for-small"
MoveLine 1
MoveLine 1
findInLine "show-for-small"
if "\"><div class=\"section_tracklisting\">"
findline "section_tracklisting"
findline "id=\"tracks_mobile\""
JoinUntil "track_preview_tracks_mobile"
# Clean up spaces between tags
RegexpReplace "[\s\t]+<" "<"
RegexpReplace ">[\s\t]+" ">"
# Get rid of "disc one", "disc two"... lines
RegexpReplace "<span class=\"rendered_text\"><strong class=\"rymfmt\">Disc[^\<\>]+?</strong></span>" ""
# Remove tables
RegexpReplace "<table[^\<\>]+?>.+?</table>" ""
# Multiple artists on the track: join them with ;
RegexpReplace "</a>(&|and|,)<a [^\<\>]+? class=\"artist\">" "; "
RegexpReplace "</a>/<a [^\<\>]+? class=\"artist\">" "; "
# Remove some unused stuff
RegexpReplace "<div class="credits_roles">[^\<\>]+?</div>" ""
GoToChar 1
# Track artist
outputto "Artist"
do
findInLine "<span class=\"rendered_text\">"
if "<a"
findInLine "class="\artist\">"
SayUntil "</a>"
movechar 4
if "&"
Say " "
SayUntil " - "
endif
else
# No artist
Say "No Artist"
endif
Say "|"
findInLine "</li>"
if "<li class=\"track\">"
else
findInLine "</li>" 1 1
endif
while "<li class=\"track\">"
GoToChar 1
# Erase any artist name before we get track names
RegexpReplace "(<span class=\"rendered_text\">)<a[^\<\>]*? class=\"artist\">[^\<\>]+?</a>([^\<\>]+?</span>)" "\1\2"
RegexpReplace "(<span class=\"rendered_text\">)&[^\-]+?- " "\1"
RegexpReplace "(<span class=\"rendered_text\">)- ([^\<\>]+?</span>)" "\1\2"
# Track title
outputto "Tracks"
do
findInLine "\"rendered_text\">" 1
SayUntil "</span>"
# Is there a Featuring?
findInLine "<div style=\"clear:both;\"></div></div>"
if "</li>"
# No credits
else
findInLine "<ul class=\"credits\">"
if "<li class=\"featured_credit\"><b>feat.</b>"
Say " (feat. "
findInLine "class=\"artist\">"
SayUntil "</a>"
Say ")"
endif
findInLine "</ul>"
endif
Say "|"
findInLine "</li>"
else
# no tracks
endif
else
# Not Various Artists
# Album artist
# In case there are two artists, merge them into one name for Album Artist
gotochar 1
RegexpReplace "(class=\"artist\">[^\<\>]+?)</a> & <a [^\<\>]+? class=\"artist\">([^\<\>]+?</a>)" "\1 / \2"
# Write tag
# findinline "class=\"artist\">"
# sayuntil "</a>"
# sayregexp "(?<=class=\"artist\">)(.*?)(?=</a>)" ";"
do
sayuntil "</a>"
findInLine "</a>"
if "<br />"
say ";"
endif
while "<br />"
# Tracks
gotoline 1
MoveLine 1
MoveLine 1
RegexpReplace "<li class=\"track\"><div class=\"tracklist_line\" style=\"width:100%;\"><span class=\"tracklist_num\"></span><span class=\"tracklist_title\"><span><span class=\"rendered_text\"><b>[^\<\>]+?</b></span></span><span class=\"tracklist_duration\" data-inseconds=\"0\"></span></span><div style=\"clear:both;\"></div></div></li>" ""
# Remove tables
RegexpReplace "</a>&<a [^\<\>]+? class=\"artist\">" "; "
# See if tracks have individual artist (like in a split with 2 artists)
findinline "<span class=\"rendered_text\">"
if "<a title=\"[Artist"
outputto "Artist"
RegexpReplace "<span class=\"rendered_text\">([^\>\<].+?)</span>" "<span class=\"rendered_text\"><a class=\"artist\">No artist</a> - \1</span>"
RegexpReplace "(<span class=\"rendered_text\"><a [^\<\>]+?) (class=\"artist\">)([^\<\>]+?<span class="subtext">\[)?(.+?)(\]</span>)?" "\1 class=\"main artist\">\4"
gotochar 1
findinline "<li class=\"track\">"
do
findInLine "class=\"main artist\">"
sayuntil "</a>"
findInLine "</li>"
say "|"
# sayregexp "(?<=class=\"main artist\">)(.*?)(?=</a>)" "|"
else
outputto "Artist"
sayOutput "ALBUMARTIST"
endif
GoToChar 1
RegexpReplace "(<span class=\"rendered_text\">)<a[^\<\>]*? class=\"main artist\">[^\<\>]+?</a>- ([^\<\>]+?</span>)" "\1\2"
# Track title
outputto "Tracks"
do
findInLine "class=\"rendered_text\">"
SayUntil "</span>"
if "</li>"
# No credits
else
Say " (feat. "
SayUntil "</a>"
Say ")"
endif
findInLine "</ul>"
endif
Say "|"
findInLine "</li>"
else
# no tracks
endif
endif
Now the request goes through with some albums, but most of the time I get : ERROR(L59/findinline): text not found. When the request is activated, I almost never get the right album in the list of suggestions, though.
I'm getting this error when I try to find artists with Japanese characters in them. I tried with only english letters and it works fine. It searches the artist, finds the artist, but gives out this error when selecting the artist to get the metadata from.
@waterproof Today I've been getting 0 results on all my album searches with a "text not found" error on line 59 like you. Here is an update that fixes it, let me know if it's still not OK for you.
@chthonic I can reproduce your problem, it's clearly an encoding issue, even though the debug info for the search results does show the URL correctly encoded for Japanese results:
Yes|Mao Denda|/release/single/傳田真央/one-last-kiss/|One Last Kiss|2001|CD||
(not exactly the URL you were trying to get, but I don't think it matters)
Yes, it's an encoding issue that seems to be special to this site. The problem is, that the fragment /release/single/傳田真央/one-last-kiss/ is not part of a valid URL.
Mp3tag expects the invalid parts of a URL (the Japanese characters in this case) to be percent-encoded at this stage. I'm not sure how to handle this yet — without breaking other things.
I've also noticed that the issue I've mentioned above is still present with this version of the script and that it produces an error if the text in L447 isn't found.
Hi @Florian ,
I'm a bit late... for some reason I stopped receiving email notifications.
I updated the script with the fix you mentioned, thanks for noticing.
About the URL encoding issue, any chance you can add a function that encodes a URL to a valid one? (like encodeURI in Javascript)
In theory it should then work with something like /release/single/%E5%82%B3%E7%94%B0%E7%9C%9F%E5%A4%AE/one-last-kiss/
Would it be possible to pull the Classifier (labeled internally as Descriptor:XXXXX) name as well? It's useful for doujin music because it contains the release events. For example, Comiket.
