When I mass tagging my mp3s, I found mp3tag messed up my tags when I entered a Chinese character whose ASCII code contains a backslash. I then try putting the backslash into the tags in another mp3 file, and the tags of the file is messed up too. I hope the problem can be fixed very soon.
Also there is another bug in file renaming. When there is a invalid character in a tag, mp3tag will suggest another file name but the Chinese characters after the removed invalid character is messed up. I hope the problem can be fixed too. (not as critical than the previous one )
Absolutely, I prefer having the option to turn that function off (as I am a double-width character set user (Chinese) and I don't use the subtitle function). On the other hand, there is no where telling users about this "function" in the application. Hope the author can provide the choice to turning this function off.
The author suggested Foobar2k's masstagger... but I found it not as easy to use as mp3tag . So I think I will stick with mp3tag instead and hoping the author make the change. What if some guys want to have backslashes in their tags?
