In version 2.42c it says:-
But I don't see that
I can add the Composer and Discnumber manually to the panel, but the "Album Artist" is not an available field?
Regards
Lee
Regards
Lee
You don't understand. This change refers to new installations of Mp3tag where the tag panel will automatically contain these 3 fields.
Besides there's no real standard for "Album Artist", so the field that is added is BAND
Here's more about the issue:
/t/7672/1
OK, I get you. So it will appear in a future release
I've added the BAND Field and labelled it "Album Artist:" and that's done the trick
Many thanks
Lee
No, it's already included. But this change comes only if you haven't installed Mp3tag before. Otherwise it would overwrite your old settings.
Gotcha!!
