[X] Album art problem
I'm not sure if this is Mp3tag bug, but still:
The problem is with embeded cover art files.
I used 4 programs to test this:
on PC Winamp and CD Art Display
on PDA: Mort player and Conduits Pocket player
When I use Mp3tag and save cover with UTF-8 (2.4) only Winamp shows the cover.
When cover is saved with UTF-16 (2.3) all programs show the cover.
Many programs don't support id3v2.4 completely.
No bug from Mp3tag.
Thanks for reply.
Bad news for me, because ID3v2.4 was introduced in 2000 and I thought this time is enough for it to be supported. I'm glad that at least Winamp supports it!
Can you add description in Mp3tag in File->Options: Write after UTFs what version is used?
What do you mean?
sorry, my mistake it's already there
