lumchen
January 15, 2005, 11:43pm
1
I am aware Mp3tag 2.27 can not correctly save Simple Chinese tag in APE files.
Winamp 5.08 will display mess characters.
On the other hand, Mp3tag will display proper Simple Chinese tag in APE files when I use Winamp 5.08 to edit and save Simple Chinese tag in APE files.
My APE files is compressed with Monkey 3.99F.
Robin
Robin,
Mp3tag doesn't support Unicode.
Best regards,
~ Florian
But according to lumchen's post, it can read Unicode APEv2 tags.
Florian,
Thank you for your reply!
I don't think that is the cause for the problem because Mp3tag can correctly save Simple Chinese tag in FLAC and MP3 files.
Also, Winamp can properly display the Simple Chinese tag in FLAC and MP3 files saved by Mp3tag.
Cheers,
Robin
Hi Robin!
Can you provide me a file containing a Simple Chinese tag?
Best regards,
~ Florian
lumchen
January 17, 2005, 12:52am
6
Florian,
you can download the two APE files at below two URLs. The two files suppose to have same Simple Chinese tag but Winamp will display mess characters with file call "Tag saved by Mp3tag.ape" and Mp3tag will correctly display two files Chinese tag. BTW, I can't use your upload service because it alway report page not found.
Robin
http://download2.chinamofile.com/905994887...by%20Mp3tag.zip
http://pickup.chinamofile.com/9059948871998988 (backup URL if above not work)
http://download2.chinamofile.com/574870294...by%20Winamp.zip
http://pickup.chinamofile.com/5748702948753065 (backup URL if above not work)
Florian,
In case you can not acess above URL, try below URL to download the 2 sample APE files.
http://lumchen.tripod.com/
Robin
Robin,
Thanks for providing these files. I'll try to find the problem.
Best regards,
~ Florian
Can you please try to disable writing of ID3v1 Tags at Options, Tags, Ape... and try to tag the file "Tag saved by Winamp.ape" again?
Best regards,
~ Florian
lumchen
January 17, 2005, 9:33pm
10
Florian,
Great!!!!!!!!!!!!!!!!!!!!!!
It works.
Cheers,
Robin
Florian
Closed
December 28, 2018, 2:14pm
12
