Ok, I user Monkey's Audio for my music backup with APEv2 Tags.
I have mp3tag set to write APEv2, and remove everything else.
This is what my file info looks like:
However, when I use the remove option on an APE file, it removes all tags including APEv2. Is this a bug?
Eric
Mp3tag V.2.29e - 03.04.2005 - 11:39:30
OS-Version: Windows XP Service Pack 2 (Build 2600)
Build: Mar 25 2005 19:38:45
AppPath: 90.131.623.936 Bytes frei (F:\music\apps\Mp3tag)
DataPath: 22.318.804.992 Bytes frei (d:\Documents and Settings\endavis\Application Data\Mp3tag\data)
TempPath: 22.318.804.992 Bytes frei (d:\DOCUME~1\endavis\LOCALS~1\Temp\Mp3tag V.2.29e)
FileVersion mfc42.dll: 6.2.4131.0
Well, according to your screenshot, MP3Tag is set to remove APE tags as well.
So, remove APE tags means remove both APEv1 and APEv2 tags?
Which means that mp3tag doesn't make a distinction between APEv1 and APEv2?
I think it should handle APE tags the same way it handles ID3 tags.
Eric
Well, ID3v1 and ID3v2 are two really different things, while APEv1 and APEv2 are almost the same.
Florian
Closed
5
