Hey guys I am not sure if this is the same problem but I am also having a problem with the comments fields. This has happened various times. I bring an mp3 into mp3Tag, I then select then i go to comments and select which normally clears the comments section. Then I deselect and Mp3tag runs. Then I select the file again but and its blank. But then I go to Winamp drop the file is and the comment is still there and its always a multi-line comment. Here is a sample:
Dano thanks for the quick reply. Yes it is exactly that I just checked ITUNNORM. Is there a way by default to tell Mp3Tag to just delete that info? Like you would with "default values" in the option screen. Maybe cliking on the save button will make that deafult. basically I just want to always delete that field when I bring a track into mp3Tag
