I'm using the latest Beta. Previously I was able to have a explorer context menu entry when right clicking INDIVIDUAL files. Now the entry only shows when right clicking FOLDERS. Has this feature changed?
There currently is no latest beta, v2.44 is the latest stable version
Are you using foobar2000? If so, it removes the context menu entries during its installation process. You can bring the context menus back by simply running Mp3tag's installer over your existing installation.
Kind regards,
Florian
Thanks. I did re-install a couple of times without any change. I then ran the registry cleaner in CCleaner and rebooted and now the context menu entry is back. I can't say conclusively what the solution was but I'm happy it's fixed.
